ERROR
When trying to establish a connection between ArcMap, the ArcCatalog or ArGIS Pro, with an SQL Server Database, the following error appears:
Error: Failed to connect to database. This release of the GeoDatabase is either invalid or out of date. DBMS table not found [Microsoft ODBC Driver 1X for SQL Server]...
The machine does not meet the minimum compatibility requirements between ArcMap or ArcGIS Pro and the SQL Server Database.
The corresponding SQL Server client library must be installed and/ or upgraded by the following the steps:
Article ID: 000027110
Get help from ArcGIS experts
Download the Esri Support App
