ERROR
Failed to connect to database. Cannot connect to database because the database client software failed to load. Be sure the database client software...
Last Published: March 30, 2023
Error Message
When attempting to establish a connection to a supported SAP HANA database in ArcCatalog on a Windows machine, the following error message may be returned:
Error:
"Failed to connect to database.
Be sure the database client software is installed and configured correctly."
image of error message
Cause
The ArcGIS client requires the SAP HANA client directory to be set in the Windows PATH environment variable.
Solution or Workaround
Update the PATH environment variable by putting the SAP client directory path at the beginning. By default, the client file is located in:
C:\Program Files (x86)\sap\hdbclient
System Properties, Advanced tab
Article ID: 000012678
Software:
  • ArcMap 10 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
