ERROR
Failed to add the rule to the geometric network. The connectivity rule is invalid/malformed.
Error Message
When adding connectivity rules to a geometric network, the following error is returned:
"Failed to add the rule to the geometric network
The subtype code does not exist. [feature class name]"
Cause
The error is caused by trying to add more than 64 junction subtypes to a particular edge-edge connectivity rule.
This error results from a known issue in ArcGIS.
Solution or Workaround
There is no workaround for this issue.
Install the ArcGIS 9.3.1 SP2 QIP Geodatabase Patch for 9.3.1 or use ArcGIS 10.1 SP1.
Article ID: 000011580
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
