HOW TO
Extract Matched address from a Map question into a text field Survey123 web designer
First Published: May 13, 2026
Last Published: May 13, 2026
Summary
When building a survey in ArcGIS Survey123 web designer from a blank survey, a common requirement is to capture a point on a map and automatically store the related address text in another field (for example, a “City” or “Address” text box).
In Survey123 web designer, this can be done without XLSForm by using a calculation that extracts a property from the Map (Location) question, such as Matched address, into a Singleline text question.
Procedure
  1. Create the survey from a blank survey:
    1. Open Survey123 web designer and create a New survey > Blank.
    2. Save the survey name and basic settings as needed.
  2. Add the Map (Location) question.
    1. From Location, add Map (this is the Location question that collects a point).
    2. (Optional) In the Map question settings, set the locator and basemap in the map configuration (Map and extent settings).
  3. Add the Singleline text question:
    • From Text, add Singleline text (example label: “City” or “Address”).
  4. Extract “Matched address” into the Singleline text question.
    1. Select the Singleline text question and open Calculation > Edit.
    2. Choose Extract data (not Number or String concatenation).
    3. Set Source to Question.
    4. Under Extract property from question:
      • Select the Map/Location question (example: “Location”).
      • Select the property Matched address.
      1. Save the calculation and preview the survey.
      Expected result
      When a respondent sets a location on the map, the Singleline text field is populated with the Matched address returned for that location.
      Article ID: 000041421
      Software:
      • ArcGIS Survey123 Website
      Get support with AI
      Start chatting now
      Related Information
      Discover more on this topic
      Get help from ArcGIS experts
      Contact technical support
      Start chatting now
      Go to download options
