PROBLEM
Exporting a feature service with domains to a CSV file shows coded values instead of descriptions
First Published: May 5, 2016
After extracting a feature service with domains to a CSV file in ArcGIS Online, the coded values display instead of the descriptions in the extracted file.
Cause
This is a known limitation of the ArcGIS Online Extract Data tool. The CSV file does not retain the description of domains because domains are a property of a file geodatabase. When exporting to any data type outside of a file geodatabase, the domain descriptions do not get exported (unless the extraction tool being used has a parameter to export with the domain descriptions); instead, the coded value is exported to the output CSV file.
Solution or Workaround
Option 1: Extract the feature service to a file geodatabase, and use the Table To Excel conversion tool with the description option enabled.
1. Log into ArcGIS Online.
2. Go to My Content, and select the intended feature service.
3. On the item details page, click the small arrow icon next to the layer to export, and select 'Export to FGDB'.
Example:
[O-Image]
4. Download and extract the exported FGDB from the item details page (Open > Download, and extract the compressed folder to an appropriate location.)
5. Open ArcMap and add the exported feature class to a blank map document.
6. Export the attributes in ArcMap using the Table To Excel tool, and check the 'Use domain and subtype description' option to include the descriptions. The Table To Excel tool is located in ArcToolbox under Conversion Tools > Excel > Table To Excel. Refer to the ArcGIS Help page in the Related Information section for more details.
Option 2: Create a local copy for editing the feature service in ArcMap, and use the Table To Excel conversion tool with the description option enabled.
1. Open ArcMap.
2. Sign in to the appropriate ArcGIS Online account (File > Sign In).
3. Add the appropriate feature service to the map from the Add Data button or the Catalog window.
4. Create a local copy for editing.
To create the local copy, ensure the Table Of Contents is in List By Drawing Order mode. Right-click the group layer > Edit Features > Create Local Copy for Editing.
5. Launch the Table To Excel tool and check the 'Use domain and subtype description' option to include the descriptions.
Article ID: 000012394
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
