PROBLEM
Exportable feature layers from an ArcGIS connection fail to export
First Published: November 23, 2022
Last Published: November 23, 2022
Feature layers from ArcGIS connections to certain ArcGIS Enterprise organizations fail to export in all formats in Insights desktop, even when export is enabled for the layer. No visible errors occur, but the exported dataset does not download.
Cause
The ArcGIS Enterprise environment does not have a TLS/SSL certificate installed from a widely recognized Certificate Authority.
Solution or Workaround
Copy the feature layer to the workbook before exporting the layer or update the ArcGIS Enterprise environment to use a TLS/SSL certificate from a widely recognized Certificate Authority.
Article ID: 000028897
Software:
  • ArcGIS Insights
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
