HOW TO
Export shapefile data into double precision coverages in ArcCatalog
Summary
ArcToolbox has an option that allows you to export data in single or double precision. It could be possible that this option is set to export data in single precision.
Export tools in ArcCatalog are the same export tools provided in ArcToolbox.
Procedure
  1. Start ArcToolbox.
  2. Select Tools > Options menu and click the Precision tab.
  3. Select Double precision for creating new data and click OK.
  4. Exit ArcToolbox.
  5. If ArcCatalog is running, exit and start a new ArcCatalog session.
  6. Right-click on a shapefile. Select Export > Shapefile to Coverage.
    The exported data should result in double precision.
Article ID: 000003212
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
