HOW TO
Export a Map Series in ArcGIS Pro with Python
First Published: August 4, 2022
Last Published: July 28, 2025
Summary
ArcGIS Pro allows exporting layouts and map series from the Share tab > Export Layout tool. Alternatively, you can also export a map series using a Python script. This article describes the steps to do this.
Procedure
  • In ArcGIS Pro, you can run the script in a Python Notebook window
  • If using Notebook, ensure the cell type is Code
  1. Enter the following expression and replace the inputs in bold
import os
aprx = arcpy.mp.ArcGISProject(r"path of the project")  #"CURRENT" can also be used to replace the path
lyt = aprx.listLayouts()[x] #x: The number of the layout within the project
ms = lyt.mapSeries
ms.exportToPDF(os.path.join(r"Output Path", f"{lyt.name}"))
print("Export Succeeded")
  1. Click Run to execute the code
The picture below shows an example of how it looks in a Notebook
You can also use an IDLE to run the script with Python, but the arcpy module must be imported as well. This module is not required when using the ArcGIS Pro environment. The same applies to the "CURRENT" value in the aprx parameter, this cannot be used outside ArcGIS Pro so you must copy the full path. The picture below shows an example:
Article ID: 000028089
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
