HOW TO
Export footprints and boundary from a mosaic dataset
Summary
The instructions provided describe how to export the footprints and boundary from a mosaic dataset in different processing contexts for ArcMap and ArcCatalog. The Copy Features tool can be used to export the footprints and boundary of a mosaic dataset as polygon feature classes.
Procedure
ArcMap
1. In ArcMap, open an MXD that contains the mosaic dataset.
2. In the Table of Contents, expand the entry for the mosaic dataset.
3. For the Footprint, right-click the Footprint entry and select Data > Export Data. The Copy Features dialog box opens.
4. Specify the output location in the dialog and run the tool.
5. For the Boundary, right-click the Boundary entry and select Data > Export Data.
6. Specify the output location and run the tool.
ArcCatalog
In ArcCatalog, a mosaic dataset is not a valid data type for the Input Features field in the Copy Features tool. Therefore, follow the instructions below to export footprints and boundary:
1. Create a mosaic layer.
2. Use the layer as an input in the Copy Features tool.
3. Create a script or model that runs both the Make Mosaic Layer tool and the Copy Features tool.
To do this in ArcCatalog, if not using a model, users can use a Python window to run the script.
See the script syntax below as an example of exporting footprint and boundary. This sample script assumes that the environment workspace is set appropriately.
Footprint
Code:
arcpy.MakeMosaicLayer_management ('MD', 'MD_Lyr')
arcpy.CopyFeatures_management (r'MD_Lyr\Footprint', r'c:\test\FGDB.gdb\Footprint')
Boundary
Code:
arcpy.CopyFeatures_management (r'MD_Lyr\Boundary', r'c:\test\FGDB.gdb\Boundary')
Article ID: 000011768
Software:
  • ArcMap
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
