HOW TO
You can use the Visual Basic for Applications (VBA) editor to write VBA code that you can execute from within ArcMap or ArcCatalog. This code is stored inside the Normal.mxt file (for ArcMap) or the Normal.gxt file (for ArcCatalog). You can export your code to Visual Basic modules, which you can import into other Visual Basic or VBA projects.
Article ID:000003473
Get help from ArcGIS experts
Download the Esri Support App
