BUG
Executing an SQL query with an ST_Geometry spatial operator fails when using an SQLite database on Linux only. The following errors are returned depending on the ArcGIS Pro version of the ST_Geometry library file.
A ‘Segmentation fault’ error is returned when using the ArcGIS Pro 2.9 and earlier versions of the library:
[testuser@XLinuxTest2265 sqlitetools_33822022]$ sqlite3 st_sqlite.sqlite SQLite version 3.38.2 2022-03-26 13:51:10 Enter ".help" for instructions Enter SQL statements terminated with a ";" sqlite> SELECT load_extension('/tmp/sqlite_stgeom/sqlitetools_33822022/Libraries/ArcGISPro_28_ST_Geometry_SQLite_177726/SQLite/Linux64/libstgeometry_sqlite','SDE_SQL_funcs_init'); sqlite> SELECT ca.OBJECTID, ca.CampingAreaName, count(*) NumCampSites ...> FROM Camping_Areas ca, Campsites cst ...> WHERE ST_Intersects(ca.Shape, cst.Shape) ...> GROUP BY ca.CampingAreaName ...> ORDER BY NumCampSites desc; Segmentation fault
An 'undefined symbol' error is returned when using the ArcGIS Pro 3.0 version of the library:
[testuser@XLinuxTest2265 sqlitetools_33822022]$ sqlite3 st_sqlite.sqlite SQLite version 3.38.2 2022-03-26 13:51:10 Enter ".help" for instructions Enter SQL statements terminated with a ";" sqlite> SELECT load_extension('/tmp/sqlite_stgeom/sqlitetools_33822022/Libraries/ArcGISPro_30_ST_Geometry_SQLite_182273/SQLite/Linux64/libstgeometry_sqlite','SDE_SQL_funcs_init'); Error: /tmp/sqlite_stgeom/sqlitetools_33822022/Libraries/ArcGISPro_30_ST_Geometry_SQLite_182273/SQLite/Linux64/libstgeometry_sqlite.so.so: undefined symbol: SES_sde_date_to_ISO8601_date
Obtain and load an updated libstgeometry_sqlite.so file from My Esri to resolve this.
This library is part of the ArcGIS Pro ST_Geometry SQLite zip file in the Database Support Files selection of the ArcGIS Pro Download Components in My Esri.
Article ID: 000028779
Get help from ArcGIS experts
Download the Esri Support App
