ERROR
This error is returned in the terminal window when attempting to initialize a Java application (Author, Designer Administrator, aimsappsrvr, aimsmonitor aimstasker):
Exception in thread "main" java.lang.UnsatisfiedLinkError: exception occurred in JNI_OnLoad at ... (some additional Java class definitions)
There are two possible causes for this error:
· The incorrect Java version is referenced when starting the Java application. Often, additional Java virtual machines are installed on UNIX machines and referenced under /bin. This directory is usually included in the system PATH variable for most user accounts.
· The X Windows libraries have not been loaded or cannot be found.
/machine1/user1/jsdk1.3.1/bin
Code:
C:>xdpyinfo
Solaris: /usr/openwin/bin/xdpyinfo
HP: /usr/contrib/bin/X11/xdpyinfo
AIX: /usr/lpp/X11/bin
If xdpyinfo cannot be found, an X Windows system may need to be installed. Refer to the appropriate system documentation for further details.
Article ID:000004525
Get help from ArcGIS experts
Download the Esri Support App
