ERROR
ESRIRegAsm.exe Error: Registration Failed. Could not load file or assembly
First Published: May 5, 2016
Last Published: July 21, 2023
Error Message
When attempting to register or unregister an ArcObjects assembly created with a previous version of ArcObjects with version 10.3, the following error is returned:
Registration failed. Could not load file or assembly 'Esri.ArcGIS.ADF.Local, Version=10.2.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86' or one of its dependencies. The system cannot find the file specified.
For example, assume that a managed COM assembly, classlibraryfor102.dll, is being registeretd that was created with 10.2 and execute the following command line to register it with 10.3:
C:\Projects\ClassLibFor102\bin\Release> "C:\Program Files (x86)\Common Files\ArcGIS\bin\esriregasm.exe" classlibraryfor102.dll /p:Desktop
The following error message is displayed:
[O-Image]
Cause
The ESRIRegAsm.exe.config file distributed with 10.3 is wrong. It currently references 10.2.0.0 and not 10.3.0.0 for the assembly binding redirection elements.
Solution or Workaround
  1. Download and unzip ESRIRegAsm.exe.config.zip to obtain a new copy of the ESRIRegAsm.exe.config file. Replace the existing file with this new version.
    The default install location of the existing config file is:
    • For 64-bit Windows operating systems: C:\Program Files (X86)\Common Files\ArcGIS\bin
    • For 32-bit Windows operating systems: C:\Program Files\Common Files\ArcGIS\bin
  2. After replacing the config file, re-execute the ESRIRegAsm.exe registration.
    For example (using the same example as before):
The following message should now be displayed:
[O-Image]
Article ID: 000012311
Software:
  • ArcObjects SDK Microsoft NET Framework
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
