ERROR
("esriGeoAnalyst.GridEngine") Could not open raster dataset from file
Error Message
The following error message appears after using the Combine tool.
"("esriGeoAnalyst.GridEngine") Could not open raster dataset from file"
Cause
A possible cause is too many unique values in the input rasters. This results in an output raster with too many unique values. The COMBINE tool cannot accept more than 10 million unique values.
Solution or Workaround
Select one of the following solutions:
  • Reclassifying the input data to have fewer unique values per raster.
  • Resampling the input rasters to create fewer unique values per raster.
Article ID: 000006953
Software:
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
