ERROR
ERROR999999, [Failed to open raster dataset], and [Client tried to access password-protected page without proper authorization]
Last Published: August 11, 2022
Error Message
The Export Training Data for Deep Learning tool fails when the image service used for input is on a different federated server from the raster analytic server. An error similar to the following and shown in the image below is returned.
ERROR 999999: [Failed to open raster dataset], and [Client tried to access password-protected page without proper authorization]
To improve performance, cluster deployments are recommended when using ArcGIS Deep Learning Studio.
Cause
There is an known issue with the portal failing to access input imagery with the expected token.
Solution or Workaround
The workaround is to temporarily share the item to be public for exporting image chips to complete.
  1. Share the input imagery layer to Everyone (public) on the portal.
  2. In ArcGIS Deep Learning Studio, collect the necessary training samples and select the Manage image chips sub-step.
  3. Export the image chips from the input image service.
  4. Once complete, change the sharing level for the input imagery layer to the desired level.
Article ID: 000028188
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
