ERROR
In ArcGIS Pro, when attempting to publish a raster dataset to ArcGIS Online, the following error message is returned.
Error: Your portal does not support this share type
By default, when sharing a raster dataset as a web layer from the Catalog pane in ArcGIS Pro, it is shared as an imagery layer, and publishing image services to ArcGIS Online is not supported.
Use one of the following options to publish a raster dataset as a web layer from ArcGIS Pro.
Publish the raster dataset as a web tile layer
In ArcGIS Pro, add the raster dataset to the map, and share it as a web tile layer to ArcGIS Online. Refer to ArcGIS Pro: Share a web tile layer using the default configuration for more information.
The image below shows the hosted tile layer available on the Content page in ArcGIS Online.
Convert the raster layer into a KML file and add it to ArcGIS Online
In ArcGIS Pro, convert the raster layer into a KML file using the Layer To KML tool, and add the KML file to ArcGIS Online through the New item option on the Content page.
The image below shows the KML layer available on the Content page in ArcGIS Online.
Publish the raster dataset as an imagery layer to ArcGIS Enterprise
In ArcGIS Pro, share the raster dataset as a web imagery layer to ArcGIS Enterprise. Refer to ArcGIS Pro: Share a web imagery layer using the default configuration for more information.
The image below shows the imagery layer available on the Content page in Portal for ArcGIS.
Article ID: 000026381
Get help from ArcGIS experts
Start chatting now
