ERROR
In ArcGIS Survey123, when opening a survey form, the form is unable to be submitted and the following error message is returned:
Error: You cannot submit records to the survey since you do not have the Edit privilege.
The user type assigned to the member does not have the privilege to submit the survey form in ArcGIS Survey123. Refer to ArcGIS Survey123: ArcGIS requirements for more information.
Note: Only an organization's default administrator or a member with administrative privileges can perform the following workflow.
Update the member's user type with the privilege to submit a survey form in ArcGIS Survey123. In ArcGIS Online, change the member’s Viewer user type to Creator, Editor, Mobile Worker, or GIS Professional. Refer to ArcGIS Online: Change user types for further instructions.
The image below shows the survey submission is successful in ArcGIS Survey123 after changing to the user type with the privilege to submit a survey form.
Article ID: 000029841
Get help from ArcGIS experts
Start chatting now
