ERROR
You cannot modify the fields of the selected table/feature class with your current license
Error Message
When changing or defining a projection in ArcCatalog with an ArcInfo license, the following error occurs:
"You cannot modify the fields of the selected table/feature class with your current license."
Cause
The file being modified, or directory path it is in, lacks adequate permissions.
Solution or Workaround
  • Ensure that the user account has FULL CONTROL for the entire path and the file itself.
  • Ensure that the file and all folders in it's complete path are not Read-only.
    [O-Image] Folder Properties
Article ID:000005398
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
