ERROR
You are not licensed for Geodatabase Editor
Error Message
After an ArcGIS upgrade with 64-bit background geoprocessing enabled, the error below is generated intermittently when running a tool. This occurs even when the tool does not perform a geodatabase editor task:
"You are not licensed for Geodatabase Editor.
Use the ArcGIS Administrator to view the software availability, change the license manager, or switch the ArcGIS software product."
[O-Image]
Cause
The cause of the error has yet to be determined.
Solution or Workaround
There are multiple options to work around the issue.
  • Disable 64-bit background geoprocessing by following the steps below:
    1. In ArcMap, navigate to Geoprocessing > Geoprocessing Options...
    2. In the Background Processing section, uncheck the 'Enable' check box to disable the background geoprocessing.
    [O-Image]
    3. Click OK and rerun the tool.
  • To continue using background processing, remove 64-bit background by uninstalling it. Tools execute in the 32-bit space when background processing is enabled.
  • To continue using 64-bit background, contact Esri Technical Support to investigate this issue. Note this technical article when contacting Support.
Article ID: 000012125
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
