ERROR
Wrong Version
Error Message
While installing the CAD Patch for ArcGIS 8.1, a "Wrong Version" error message is returned.
Cause
This is a known issue. The Desktop CAD Patch default installation directory is C:\arcexe81. However, the actual directory that ArcGIS is installed in may be different.
Solution or Workaround
  1. Click the Back button on the Wrong Version dialog box.
  2. Specify the directory where ArcGIS is installed on the Select Destination dialog box, for example, c:\arcgis\arcexe81.
  3. Click OK.
    You can create the BACKUP directory as a child to the arcgis directory.
Article ID:000004508
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
