ERROR
The following error is displayed when using the Select by Rectangle tool to select some features and then zoom to those features in an HTML Viewer:
Code:
Unable to display map service. AXLParser: 'minx' not found in envelope
The error message is seen only when selFieldList[] and fieldAliasList[] are defined in the ArcIMSparams.js file.
The problem occurs because the selFieldList contains incorrectly defining ID and/or SHAPE fields in the ArcIMSparams.js file.
Code:
selFieldList[0]="ID SHAPE BLOCK LOT UID MUN ACRES IMAGEFILE SHTSCALE QUAL";
The ID and SHAPE fields should be enclosed within # sign as in the example below.
Code:
selFieldList[0]="#ID# #SHAPE# BLOCK LOT UID MUN ACRES IMAGEFILE SHTSCALE QUAL";
The #SHAPE# and #ID# fields are required unless #ALL# is used. Also, the order of these fields is not important.
Article ID:000007879
Get help from ArcGIS experts
Download the Esri Support App
