ERROR
When adding a shapefile to a view, "Feature table has error - unable to make theme" occurs
Error Message
The following error occurs when adding a shapefile to a view:
"Feature table has error - unable to make theme."
Cause
The theme attribute table is corrupt.
Solution or Workaround
Use Microsoft Excel to redefine the extent of the theme's .dbf file.
  1. Open the .dbf file associated with the theme in Excel.
  2. Click Insert > Name > Define.
  3. Select the word Database from the list on the Define Name dialog box.
  4. Click the button at the bottom right-hand corner.
  5. Click the upper left-hand cell and drag a box to the lower right-hand cell.
  6. Save the file as a .dbf with the same name as the original table.
Article ID:000003857
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
