ERROR
Warning - Unable to locate the Help file Generator
Error Message
The ArcView setup routine returns this message:"Warning - Unable to locate the Help file Generator"ArcView starts without a problem, but the help system will not initialize.
Cause
A missing, outdated, or corrupt winhlp32.exe file.
Solution or Workaround
Make sure the winhlp32.exe file resides on you machine. If it does, try replacing it with a copy from another machine.
Article ID:000003859
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
