ERROR
Warning: Invalid entry. Spaces are not permitted in path name.
Error Message
Some tools and wizards return this message when trying to access a dataset:
"Warning: Invalid entry. Spaces are not permitted in path name."
Some of the tools and wizards will run but one of these execution errors messages will be produced:
"Too many arguments entered"
"Keyword token expected"
Cause
ArcInfo Workstation commands for working with coverages, GRIDs, TINs, shapefiles, or dBASE tables don't support paths names that contain space characters. Since these commands are used by many ArcGIS tools, this limitation applies to them as well.
Solution or Workaround
  • When the path name contains space characters: copy your data to a new workspace that does not have a space characters in its path name.
  • When the dataset has a space character in its name: rename the dataset to eliminate the space.
Article ID:000003119
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
