ERROR
Attempts to import a feature class containing CAD data into a geodatabase fail, and return the following error message:
Error: WARNING 000594: Input feature <value>: falls outside of output geometry domains
This issue occurs if the feature class contains CAD data. When using AutoCAD 2016, the DWG file format version is not supported by ArcMap version 10.4 and prior. Hence, when attempting to import a feature class containing CAD data to a geodatabase, the process fails.
Additionally, when using other variants of AutoCAD such as Civil 3D or Land Desktop, the features generated by these programs are created using the ObjectARX API. Data created using the ObjectARX API uses a custom code which ArcMap does not have access to.
Note: As of ArcMap version 10.5, the DWG file format version for AutoCAD 2016, and AutoCAD 2017 are supported.
Article ID: 000014288
Get help from ArcGIS experts
Start chatting now
