ERROR
(vrec) No Free Channels
Error Message
This error occurs when using the Merge themes script, or when merging themes through the Geoprocessing Wizard:
(vrec) No Free Channels error
Cause
You have exceeded the processing resources of your computer, which are based on memory and swap space.
A channel is an ESRI system resource that declares x number of channels in memory. In most cases channels refer to the number of file handles available for the system to use. Most functions in ArcView, such as bitmaps or data selections, have 30 channels declared.
Solution or Workaround
Do the processing in smaller increments, such as merging 3 themes at a time instead of 10.
When merging through Avenue, use the anAppl.PurgeObjects request to release memory.
Article ID:000002549
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
