ERROR
Validation failure: Could not find schema information for the element 'http://www.esri.com/schemas/ArcGISExplorer/1500/Addins:ExplorerAddIns'
Error Message
Building an ArcGIS Explorer add-in project in Visual Studio can result in one or more validation errors in the Visual Studio Error List window with the following message:
"Validation failure: Could not find schema information for the element 'http://www.esri.com/schemas/ArcGISExplorer/1500/Addins:ExplorerAddIns'."
Cause
From version 1500 onwards, the AddIns.xml file created by the ArcGIS Explorer Tools for Visual Studio contains a new XML namespace attribute. This namespace is not applicable to previous releases and causes a build error if the add-in project created with ArcGIS Explorer 1500 is built on a machine on which ArcGIS Explorer 900 or 1200 is installed.
Solution or Workaround
This error can be resolved using the steps below. Alternatively, if possible, consider upgrading to the latest version of ArcGIS Explorer and the ArcGIS Explorer SDK for the Microsoft .NET Framework.
  1. In Visual Studio, open the AddIns.xml file that is part of the add-in project.
  2. In the editor window, locate the top-level ExplorerAddIns node.
  3. Delete the 'xmlns' attribute and associated value from the ExplorerAddIns node.
  4. Compile the add-in.
    If new build errors are found, such as 'The type or namespace name 'CheckBox' does not exist in the namespace 'ESRI.ArcGISExplorer.Application' are you missing an assembly reference?)', the add-in may be using functionality that was introduced in a later version of ArcGIS Explorer than the version currently installed. Resolve any issues by using alternative code that is supported by the ArcGIS Explorer version currently installed. Refer to the ArcGIS Explorer Developer Help for more information on new API types and members added at version 1500. The Developer Help is installed as part of the ArcGIS Explorer SDK for the Microsoft .NET Framework and is also available online from the Esri Web site at ArcGIS Explorer Online Help.
Article ID:000011026
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
