ERROR
Validate Topology failed. A failure was detected inside the topology engine overlay processor. [error id: 221]
Error Message
When validating a topology containing one or more polygon feature classes and the 'Must Not Overlap' topology rule, ArcMap or ArcCatalog returns one of the following errors:
"Validate Topology failed. A failure was detected inside the topology engine overlay processor. [error id: 220]", or
"Validate Topology failed. A failure was detected inside the topology engine overlay processor. [error id: 221]".
Cause
When a topology is validated, where the 'Must Not Overlap' rule is applied to a feature class with many coincident polygons, a very large number of topology errors are generated. These messages are returned when the maximum error count allowed during a validate operation has been exceeded.
Solution or Workaround
This scenario often occurs with high-rise condominiums, where each floor is represented by a polygon.
One data modeling solution is to have one floor plan (one polygon feature), and create a relationship between the building footprint and a non-spatial table containing rows for each floor.
Another solution is to create a subtype defined for the condominiums in the feature class, and do not specify the the 'Must Not Overlap' topology rule for the condominium subtype.
Article ID:000009961
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
