ERROR
During the post-installation of ArcIMS 9.1, on the Web Server Servlet Engine Configuration dialog, when the 'IIS with Tomcat 4.1.xx/5.0.28' option is selected; the following message appears:
"Web server-Servlet Engine Configuration completed with errors. Do you want to view the log file: C:\Program Files\ArcGIS\ArciMS\Tools\ArcIMSCfgTool_InstallLog.log"
If the log is viewed, the following errors are recorded:
"1 NONFATAL ERRORS
CfgWebServer workers2.properties
status: ERROR
Additional Notes: ERROR Required file does not exist. Could not configure web server."
ArcIMS 9.1 was initially released and tested with IIS/Tomcat 5.0.28 and used two files: isapi_redirector2.dll and workers2.properties. Due to known issues with ArcIMS and that configuration, it was necessary to move to a different configuration with the isapi_redirect.dll.
The configuration with isapi_redirect.dll does not work with the ArcIMS Post Installation, and the servlet connector needs to be manually configured using the steps in the ArcIMS Installation Guide (install.htm) on the Windows CD.
Article ID:000008163
Get help from ArcGIS experts
Download the Esri Support App
