ERROR
Attempts to run any GeoAnalytics tool in ArcGIS Pro after signing in with ArcGIS Enterprise credentials fail, and return the following error:
Error: UseSSOIdentityIfPortalOwned was not found.Failed to execute.
Note: The tools execute successfully in Map Viewer.
ImportToolbox and AddToolbox are used to import or add toolboxes from different origins, including ArcGIS Server, and are used in a script. The UseSSOIdentityIfPortalOwned key prompts a sign in, and grants access to secured services. In this example, secured services refer to the geoprocessing services toolbox file; the System or GeoAnalyticsTools toolbox file from the ArcGIS Server URL shown in the error message above. If the user is signed in, the process is successful.
The GeoAnalytics Server site (a one-node machine, in this case) is federated with Portal for ArcGIS, and requires the user to log in to Portal to utilize the tools.
ArcGIS Pro cannot find the server, as the GeoAnalystics Server's root certificate is untrusted. An untrusted certificate may range from self-signed certificates to certificates issued by unrecognised certification authorities.
Use a trusted certificate issued by well-known certification authorities. This is usually installed on any Windows machine by default, and can be viewed in the Microsoft Management Console.
Another option is to import the self-signed root certificate to the ArcGIS Pro client machine using Microsoft Management Console(MMC). To do so, complete the following steps:
Article ID: 000022251
Get help from ArcGIS experts
Start chatting now
