ERROR
User-defined class has the name of a class inside the ESRI Classes package (reserved)
Error Message
The ESRI Semantics Checker returns the following error:
"User-defined class has the name of a class inside the ESRI Classes package (reserved)."
Cause
A common cause is the Logical View package and Workspace package are both stereotyped as Workspace in the UML model.
User-defined classes should exist below the Workspace package.
Solution or Workaround
Remove the Logical View stereotype.
  1. Right-click on Logical View in the Model Explorer.
  2. Select Properties.
  3. Select Package under Categories.
  4. Select the empty line in the Stereotype drop-down menu.
  5. Click OK.
Article ID:000007824
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
