ERROR
Usage SHADSET [shadeset_file {clear}/*
Error Message
The following error message is received when running the PROJDB SML:"Usage SHADSET [shadeset_file {clear}/*"
Cause
A line is missing in the PROJDB SML.
Solution or Workaround
Add the following line to the PROJDB SML as the first line in the second paragraph of code:
Code:
SET &SV 1 COLOR
You can use Notepad or Wordpad to edit the SML.
Article ID:000005460
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
