ERROR
Unknown Object "SpAnEnv. 10719" in Project "c:\TEMP\template.def." "Template file is invalid. Please check your installation."
Error Message
When either creating a layout based on an existing template or creating a new template, the following error occurs: Unknown Object "SpAnEnv. 10719" in Project "C:\TEMP\template.def"
"Template file is invalid. Please check your installation." Note that the number following 'SpAnEnv' can be any number.
Cause
A layout template found at the location specified in the error message was created when the Spatial Analyst extension loaded.
Solution or Workaround
The following are two options which allow you to work around this error.
  • Delete or rename the template.def file in the directory referred to in the error message. This option will not allow use of any previously created templates.
  • Load the Spatial Analyst extension before using or creating the template.
Article ID:000004934
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
