ERROR
Portal for ArcGIS: Unauthorized Unable to sign in. Try again.
Last Published: August 4, 2025
Error Message
When accessing the Portal for ArcGIS home page, the following error is returned:
Error:
Image of the error in the portal home page.
When accessing the Portal Administrator Directory, the following error is returned:
Error:
Site Root -/
 Version: 10.x.x
Site is inaccessible. Contact your Portal administrator
Cause
The issue is caused by the disk location for "arcgisportal\content" running out of space after publishing large datasets, which fills up the disk space. The portal logs indicate the "disk running out of space" warning.
Solution or Workaround
Add or free up disk space on the drive where the "arcgisportal" and "content" directories are stored, then restart the Portal for ArcGIS service. Refer to Portal for ArcGIS: Stop and start the portal for more information.
Article ID: 000024157
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
