ERROR
When writing to the 'GML - Geography Markup Language' format using the Data Interoperability Quick Export or Spatial ETL tool, the following error message occurs:
"<GML Writer> - Unable to write feature geometries without an FME Coordinate System. Either tag the FME features with a coordinate system, or use the GML writer SRS_NAME along with the SRS_AXIS_ORDER keywords to specify the GML srsName and axis order for the GML <pos> and <posList> elements".
The 'GML - Geography Markup Language' format requires that the dataset has a coordinate system.
If the source data's coordinate system is undefined, use the Define Projection geoprocessing tool to define the coordinate system of the source data.
If the source data is undefined, set the coordinate system of the output (destination) GML file by selecting the correct coordinate system from the Spatial References dialog box.
If using the Quick Export tool, the Spatial References dialog box can be accessed from the Coordinate System's browse button on the Specify Output Data Destination dialog box as shown below:![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000009777/00N39000003LL2C-0EM39000000wd4y.png)
If using a Spatial ETL tool, the coordinate system is a parameter of the dataset that can be set in Workbench.
Article ID: 000009777
Get help from ArcGIS experts
Start chatting now
