ERROR
Unable to run file filename.aml
Error Message
Trying to run an AML returns the following error:Unable to run file filename.aml
Cause
When the AML was saved, a .txt extension was appended to the filename by the text editor.
Solution or Workaround
  1. Display file extensions in Windows Explorer.
    Windows NT
    A. Select View > Options.
    B. Click the View tab.
    C. Make sure the 'Hide file extensions for known file types' radio dial is not checked.
    Windows 2000
    A. Select Tools > Folder Options.
    B. Click the File Types tab.
    C. In the Advanced Settings box make sure 'Hide file extensions for known file types' is not checked.
  2. Right-click the AML in Windows Explorer and use Rename to remove the .txt extension.
  3. Select Yes when a message box appears saying "If you change a filename extension, the file may become unusable. Are you sure you want to change it?"
Article ID:000003573
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
