ERROR
Unable to reach the server where the service is. Consider using calling deleteItem with options = { 'force' : true } if the server won't be available anymore
First Published: July 11, 2019
Last Published: July 29, 2025
Error Message
Attempting to delete a detached item in the My Content tab in Portal for ArcGIS returns the following error message:
Error:
Unable to reach the server where the service is. Consider using calling deleteItem with options = { 'force' : true } if the server won't be available anymore.
Image showing the error message
Cause
The error occurs when Portal for ArcGIS is unable to reach the server hosting the service of the detached item. Described below are potential causes for this issue:
  • Common certificate issue, for example, a mismatch in certificate name of the elements of the federated environment: Portal for ArcGIS, ArcGIS Server, and IIS Web Server
  • A mismatch in the Service URL and Administration URL during configuration setting in federation
Solution or Workaround
Instead of re-configuring the connection between Portal for ArcGIS and the server, users may opt to force delete the detached item using the deleteItem operation in the Portal REST API directories. To do so, refer to the workflow described below:
Only administrators have the privileges to perform the steps below.
  1. Obtain the item ID of the detached item.
    1. Navigate to the following URL:
https://<Portal URL>/sharing/rest/content/users/<username>
  1. In the User Content section, click the ID - Title of the detached item.
A screenshot of the User Content section
  1. In the User Item section, copy the item ID.
A screenshot of the User Item section
  1. Navigate to the following URL, after inserting the item ID copied from step 1 between items and delete, as shown below.
https://<Portal URL>/sharing/rest/content/users/<username>/items/<itemid>/delete
  1. Check the Force deletion? check box, and click Delete Item.
An image of the Delete Item box.
The detached item is deleted.
Article ID: 000020655
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Web Adaptor
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
