ERROR
Unable to publish the survey. ERROR: Adding field to the table failed
First Published: April 15, 2020
Last Published: May 5, 2022
Error Message
Publishing a survey from the ArcGIS Survey123 website to Portal for ArcGIS fails and returns the following error:
Error:
Unable to publish the survey. ERROR: Adding field to the table failed.
The error message
Cause
The known causes for the error are as follows:
  • A question is added and removed from the survey without being used. This creates conflicting fields on the new questions added in place of the removed question.
  • The survey does not honor the ArcGIS Enterprise publishing requirements.
Solution or Workaround
Depending on the cause, complete either one of the methods provided below to resolve.
The survey contains conflicting fields
Republish a new survey based on the existing survey.
  1. In the ArcGIS Survey123 website survey gallery, navigate to the survey, and click More options > Save As.
  2. In the Save As New Survey window, fill in the required sections, and click Save As.
  3. Open the new survey, and edit the conflicting fields.
  4. Click Save > Publish.
Refer to ArcGIS Survey123: Limitations for more information on the publishing requirements.
Alternatively, publish the survey using the ArcGIS Survey123 Connect desktop app. Publishing the survey from the desktop app narrows down the exact cause, as the desktop app specifies the cause of the error instead of returning a generic error message in the ArcGIS Survey123 website. Refer to ArcGIS Survey123: Publish a survey for steps to publish a survey from the desktop app.
Article ID: 000023156
Software:
  • Portal for ArcGIS
  • ArcGIS Survey123 Connect
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
