ERROR
Unable to create new shapefile, permission is denied
Error Message
In ArcMap, attempting to create a shapefile from the Catalog tree returns the following error message:
Error:
Unable to create new shapefile, permission is denied.
The error message is also returned when attempting to save the shapefile in a system folder such as Windows, Program Files, and Program Files (x86).
Cause
The following are probable causes:
  • The shapefile name contains characters such as the forward slash (/), backward slash (\), bar (|), and asterisk (*), which are not supported in ArcGIS Desktop.
  • The user is unable save the shapefile in the folder location due to insufficient permissions to read or write in the system folder.
Solution or Workaround
Depending on the cause, select one of the options below to resolve the issue:
Article ID: 000021456
Software:
  • ArcMap
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
