ERROR
Unable to communicate with ArcGIS Online. Requires external access to ArcGIS Online and cannot be used in a disconnected environment
First Published: November 24, 2020
Last Published: August 4, 2025
Error Message
The following notice is returned when trying to configure ArcGIS Online's Utility Services with ArcGIS Enterprise.
Notice:
Unable to communicate with ArcGIS Online. This feature requires external access to ArcGIS Online and cannot be used in a disconnected environment
image of message
Cause
The Portal for ArcGIS environment has a forward proxy configured, but the system properties in the Portal Administrator Directory are not configured as per the Configure your portal to use a forward proxy server documentation. This can also be confirmed by tracking developer's tool requests where:
https://proxy.domain.com/portal/sharing/proxy?https://www.arcgis.com/sharing/rest/portals/self?f=json
fails with the error:
net::ERR_ABORTED
Solution or Workaround
The incorrect port was specified for the forward proxy in the Portal system properties. Also, an inappropriate WebContextURL was included. The below modifications can be made to fix this issue:
  1. Log in to Portal Admin > System > Properties > Update Properties
  2. Modify the WebcontextURL parameter to use the Portal web adaptor.
  3. Ensure that the appropriate machine names are included in the nonProxyHosts parameter.
  4. Ensure that the correct ports are specified in the httpProxyPort and httpsProxyPort parameters.
  5. Update the properties and restart the Portal for ArcGIS service.
Article ID: 000024432
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
