ERROR
Unable to add layer to the map or establish a secure HTTPS connection to the layer in ArcGIS Online
Last Published: February 9, 2024
Error Message
After changing the source of a layer view in ArcGIS Online, opening the layer view in Map Viewer fails and returns the following error message:
Error:
Unable to add layer: Unable to establish a secure HTTPS connection to the layer. The layer, <layer name>, cannot be added to the map.
A view layer in ArcGIS Online Map Viewer.
Cause
  • The layer ID for the source layer view is different.
  • The layer is corrupted.
Solution or Workaround
Match the layer ID in ArcGIS Pro
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the map and click Properties to open the Properties dialog box.
  3. In the Map Properties dialog box, click the General tab.
  4. Check the Allow assignment of unique numeric IDs for sharing web layers check box.
  5. Click OK.
The Map Properties dialog box in ArcGIS Pro.
  1. In the Contents pane, right-click the layer with the mismatching layer ID, and click Properties.
  2. In the Layer Properties dialog box, click the General tab.
  3. For the Layer ID parameter, input the matching layer ID of the source data.
  4. Click OK.
The Layer Properties dialog box in ArcGIS Pro.
  1. Overwrite the layer. Refer to ArcGIS Pro: Overwrite a web feature layer for further instructions.
Recreate and republish the layer
Delete the corrupted layer from ArcGIS Online and recreate the layer before republishing.
Article ID: 000031507
Software:
  • ArcGIS Online
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
