ERROR
Type 2 error
Solution or Workaround
Error Message
ArcView does not run on a Mac G3 running OS 8.1, even when no other programs are installed. ArcView installed without problem, but when it is initialized, a type 2 error message occurs. ArcView runs successfully on non-G3 machines running 8.1.
Cause
It appears to be a hard drive partition issue.
Solution
Try partitioning the hard drive into two separate, equal-size drives. Keep the system on one drive and install ArcView on the other.
This may not work in all situations.
Article ID:000001501
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
