ERROR
This file cannot be accessed." Make sure you have security privileges on the drive.
Error Message
When using the Import71 utility to import ArcInfo interchange files (.e00), the following error occurs:"This file cannot be accessed." Make sure you have security privileges on the drive.
Cause
There is not enough space on the drive and/or in the directory. A directory nearing 100MB may cause problems for ArcView saving to that directory.
Solution or Workaround
  • Save the file to a new empty directory.
  • Remove any unnecessary files from the desired directory.
Article ID:000004994
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
