ERROR
After Portal for ArcGIS 10.6 installation is completed, the portal homepage loads in the browser. Clicking the Continue Portal Upgrade button returns the following error message:
Error: There was an error when attempting to upgrade the existing portal. Web server SSL Certificate does not match list of certificates.
The portal keystore contains certificates imported to Portal for ArcGIS. This issue occurs when the portal uses a signed Certificate Authority (CA) that no longer exists in the certificate keystore (portal.ks).
Note: The field might already be pre-populated with 'portal', but proceed with step 3. This updates the certificate alias in the portal's internal database.
Article ID: 000018157
Get help from ArcGIS experts
Start chatting now
