ERROR
There was an error when attempting to accept the invitation response
Last Published: May 23, 2023
Error Message
When attempting to import an invitation response for a Portal for ArcGIS and ArcGIS Online distributed collaboration, the following error message is returned:
Error:
There was an error when attempting to accept the invitation response.
The error message.
Cause
An incorrect guest organization URL address is specified in the invitation link to generate the distributed collaboration invitation file. This may include an incorrect web adaptor name in the URL address.
Below are examples of incorrect and correct URL addresses.
Incorrect URL:
https://<machine_name>:<port_number>.domain.com/arcgis/home
Correct URL:
https://<machine_name>.domain.com/webadaptorname
Solution or Workaround
Remove and reinvite the guest organization
Remove and reinvite the guest organization using the correct URL.
If deleting and reinviting the guest organization fails, contact Esri Support to delete the old invitation URL logged to the gw_participant_info table in the ArcGIS Online database.
Create a new distributed collaboration
  1. Log in to an ArcGIS Online account with administrative privileges.
  2. Delete the existing distributed collaboration. Refer to ArcGIS Online: Delete a collaboration for more information.
  3. Create a new distributed collaboration. Refer to ArcGIS Online: Create a distributed collaboration for instructions.
When inviting a guest to the collaboration, ensure the correct URL address format as specified in the Guest Organization URL is entered in the box for the invitation.
The Invite Guest Organization window.
Article ID: 000027934
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
