ERROR
The value you have entered is out of range or is not a whole number
First Published: October 10, 2017
Error Message
When adding a value in an attribute table, the following error is returned in ArcMap:
Error:
User-added image
Cause
There are two causes that can lead to this error:
  • The value entered is outside the storable range of the field data type. For example, a short integer data type cannot store a value more than 32,767. For more information on the storable range of a field data type, read the following ArcGIS Help, ArcGIS field data types.
  • Text is entered in a numeric data type field.
Solution or Workaround
Change the field type to what is appropriate for the data type of the value, or add a new field with a field type that matches the data type of the value. For more information, refer to the following ArcGIS Help documents: Modifying field properties and Adding fields.
Before editing fields of a feature class, ensure that the data is not locked. For more information on schema locks, refer to the following ArcGIS Help: Schema locking.
Article ID: 000014935
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
