ERROR
The tool is not licensed
Error Message
When attempting to create a globe cache in ArcCatalog for an ArcGIS Server globe service using the Manage Globe Server Cache Tiles tool, the following error message is returned:
Error:
The tool is not licensed.
Cause
The 3D Analyst extension is not licensed or enabled in ArcCatalog.
Solution or Workaround
To successfully create a globe cache, the 3D Analyst extension is required for ArcGIS Desktop. The extension must be available and enabled in ArcCatalog. To do this, follow the steps outlined below:
  1. Check if the 3D Analyst extension is licensed and available via ArcGIS Administrator. Launch ArcGIS Administrator. Select the Availability folder.
    Image of the availability of 3D Analyst Single-Use licenses in ArcGIS Administrator
     In License Server Administrator
    Image of the availability of 3D Analyst Concurrent-Use licenses in ArcGIS Administrator
  2. Enable the extension in ArcCatalog. In ArcCatalog, navigate to Customize > Extensions. Ensure 3D Analyst is checked.
    Image of the Extensions window in ArcCatalog.
Article ID: 000019458
Software:
  • ArcMap
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
