ERROR
Resizing the CityEngine window causes the application to crash
Last Published: May 30, 2024
Error Message
When trying to resize the CityEngine window, the appliation crashes with the following error message:
"The Service NahimicService was detected on your system. Resizing CityEngine windows can lead to crashes when this service is active. Please deactivate the service or if that is impossible add the following line to the CityEngine.ini in your CityEngine installation: '-Dglsinglebuffer'. This activates single buffering and can lead to degraded rendering performance. - [Worker-4: Check for NahimicService]"
Cause
The Service NahimicService was detected on the system.
From Google search:  "The Nahimic service is an audio driver that will cause eSignal to lock up or stop responding. it can come preinstalled with Dell, ASUS computers, ASUS motherboards and MSI brand pcs as well as Nvidia video cards."
Microsoft provides additional information. The Nahimic Service is NOT a virus. Read more on about Nahimic audio software on this Microsoft Community discussion.
Solution or Workaround
Notice that the error message above includes the instructions on how to resolve this issue.  The following steps are provided:
  1. Deactivate the NahimicService if possible.
  2. If unable to deactivate the service, add the following line to the CityEngine.ini in your CityEngine installation: '-Dglsinglebuffer'. This activates single buffering and can lead to degraded rendering performance.
  3. Open the folder: C:\Program Files\ArcGIS\CityEngine2022.1 (or other version number).
  4. Open CityEngine.ini using NotePad. Do not use NotePad++ or other text editors, these may add formatting characters that corrupt the file.
  5. Below the line @NoDefault add the following string:
-Dglsinglebuffer
Article ID: 000032745
Software:
  • ArcGIS CityEngine
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
