ERROR
The script is not compiled
Error Message
This error occurs when creating custom view buttons for a project:
"The script is not compiled."
Cause
There are two possible causes for this error:
· The script is not compiled.
· Two or more documents within the project have the same name.
Solution or Workaround
  • Click the compile button to compile the script.
    [O-Image] Script compile button
  • Change the name of the document.
    1. Make the script, view, or layout active.
    2. Select Properties from the Script, View, or Layout pull-down menu.
    3. Type a new name for the document in the Name field.
    4. Click the OK button.
Article ID:000004403
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
