ERROR
The report template can't be saved due to some server issues
Error Message
Attempts to add a report template file (.brpt) to ArcGIS Business Analyst using the 'Add template from file' option fail with the following error message:
Error:
The report template can't be saved due to some server issues.
Error message.
The report template file is provided by a different organization.
Cause
The report template is referencing feature layers that are not available in the organization it is added to.
Solution or Workaround
To resolve this issue, remove all the feature layers attached to the report template. The following workflow must be performed in the report template creator's organization. In this example, there is only one feature layer attached to the report template.
  1. In ArcGIS Business Analyst, click the Reports tab. Click Build Reports > Select reports.
  2. In the Select a report. section, click My reports. Hover over the report to be shared, and click the Edit report icon.
Edit report.
  1. In the Create report template. section, click Edit.
  2. Hover over the map, and click Add other layers.
Add other layers.
  1. In the Add Layers to Map window, under the Add layer section, hover over the feature layer, and click the Remove layer Remove layer. icon. If there is more than one feature layer, remove all of them. Click Apply, and Save the report template.
Remove layer.
  1. In the Save report template window, specify a Title for the report template, and click Save.
  2. In the My reports section, hover over the saved report template, and click Download Download..
The report template can be shared and added to ArcGIS Business Analyst reports from other organizations.
Article ID: 000022873
Software:
  • ArcGIS Online
  • ArcGIS Business Analyst Web App
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
